no heat coming out in the floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2007, 06:27 PM
cannonball63
my 98' s-10 & Dads 2000'GMC Sonoma have the same problem. The heaters wont blow heat in the floor. Everywhere else yes, but not the floor. Anyone here got the solution? many thanks for the answer.
Old 11-06-2007, 12:57 AM
Always look up in a custom
Is the flap working on the heater outlet down low? I've never had one apart, but aren't there relays in the system to trigger the flaps to open and close (no longer cables running out to them, right?).
Or if debris got down in it through the outside vent on the cowl and it's blocked a passage.
Old 11-06-2007, 05:29 AM
Last journal entry: Bringing home the 401 Nailhead
Not sure about a Sonoma but my Astro uses vacuum to control the flaps. Check all the vacuum lines for cracks/leaks
Old 11-06-2007, 06:39 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm going to move this thread to General Rodding Tech. You will get better answers there.
Dan
Garage Heat swvalcon Garage - Tools 10 11-27-2009 10:55 PM
Can I use heat to relax metal after stretching? Ripped Body - Exterior 10 11-16-2006 11:36 PM
floor fabrication johnnymopar Body - Exterior 2 03-13-2006 07:00 PM
starting the floor modas Body - Exterior 1 07-17-2005 06:39 PM
Choke heat tubes - how important? cboy Engine 2 05-11-2005 06:34 PM
