NO holes on 283 for AC Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2008, 10:36 AM
I am trying to hook up a Vintage AIR AC unit on a 1967 283 SB Chevy. However, there are no holes on the passenger's side for a bracket. Is there an alternate mounting bracket for this application - maybe hooked onto the water pump bolt?
Old 07-28-2008, 10:52 AM
poncho62's Avatar
Wiki Edits: 5
Maybe......Not sure of the AC setup on the earlier cars.....Starting in 69, when Chevy went to the long water pump, the heads had the extra bosses and mounting holes for the passenger side mounted alternator........If memory serves me right, the AC compressor was in the middle above the water pump...but I could be wrong.
Old 07-28-2008, 11:08 AM
302 Z28's Avatar
Vintage Air should have the proper brackets for mounting on a pre 69 SBC, give them a call. Whatever you do, do not take anyone's advice to drill and tap the early heads. 9 times out of 10 it won't work and you wind up with unusable heads.
Vince
Old 07-28-2008, 12:38 PM
All the vintage air systems I've seen take into account that the engine doesn't have mounting holes in the heads, if the system was designed for a car that shouldn't have those heads.
My '64 El Camino mounts the compressor by the exhaust manifold bolts and the water pump bolts. There were spacers provided in case headers were installed.
JA
Old 07-28-2008, 09:40 PM
You could get a catalog from Bill's Hotrod Company 1064 E. Edna Place, Covina, California, 91724 phone 625-332 1915. Good people, good prices, great brackets. I have no conection with this company. Dave 39
Drilling holes for accessory mountings-- can it be done? schnitz Engine 11 07-01-2008 08:27 PM
Sanden A/c Compressor Unused Mounting Holes cometman General Rodding Tech 0 09-23-2007 01:37 PM
high performance 283 steve Engine 2 06-22-2003 04:25 PM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 12:55 PM
a/c bracket? compressor? oldcarguy85 Engine 3 04-23-2002 06:14 PM
