no horn or dome light what do I do next - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2009, 09:08 PM
HI everyone my 80 Z28 gave me a little look its spring time problem,my interior dome light and both my horns are not working, any suggestions,if it a fuse box problem how do I knowwhich terminal it is. thanks in advance
Old 03-28-2009, 11:08 PM
Both the horn and the dome light are switched to ground I believe. Check the fuse. Anything else not working?
Old 03-28-2009, 11:27 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I agree with this question. Anything else not working?
Check the main body ground by the battery, and or it's connection to the 'negative' terminal connection at the battery. It could have corrosion at the battery, or inside of the small 10 gauge wire, that is causing electrical problems within the 'body' ground/power circuits.
64 Impala Horn Problem dmaggard Electrical 28 09-14-2006 12:01 AM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
How many Forum members.............. Stitch Hotrodders' Lounge 29 03-11-2004 07:31 AM
a little humor to get through the evening antirice Hotrodders' Lounge 7 08-28-2003 08:36 AM
Fuse blows Horn dome light and the back hatch th2hh Electrical 3 08-24-2003 07:44 PM
