No horsepower of my 70 chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2011, 12:49 PM
I have a timing question for you guys, when checking my timing with my vacuum advance plugged off, when i rev the engine my timing mark comes up smoothly, the problem i see is when i hook up my vacuum advance and quickly rev the motor my timing drops off about 8 degrees first and then starts to advance normally, I believe this has something to do with motor dying when given full throttle from a idle, somebody have any ideas. Thanks Kamutr. P.S. I am running on manifold vacuum.
Old 04-28-2011, 01:26 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What distributor and carb are you running on it ?
Cole
Old 04-28-2011, 01:44 PM
When you open the throttle manifold vacuum drops and along with it the amount of vacuum advance. The solutions are several but probably the easiest is to plug the vacuum advance into the carb's timed port and increase the amount of base advance to compensate for the lost amount vacuum advance at idle.
Bogie
Old 04-28-2011, 05:03 PM
No horsepower on my 70 chevelle
I running a carter 625 and a Mallory Hei dist. with adjustable vacuum
Old 05-01-2011, 09:13 AM
no horsepower on my70 chevelle
Thanks Bogie, I give that a shot, also after reading up on the carter 625 according to the manual for the carter/rodchester 500-650 they don't work well with the air gap manifolds when looking for full throttle from idle when in conjuction with a moderate to big cam.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
No horsepower for my 70 Chevelle kamutr Engine 8 04-27-2011 11:34 AM
Will a 69 Chevelle rearend fit my '67 Chevelle lt1_performance Transmission - Rearend 2 04-26-2008 10:10 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 09:25 AM
