no idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 05:56 AM
no idle
i have an 89 chevy suburban with the 350 engine. it wont idle, and after unhooking the map sensor, it idles fine. i replaced the map sensor and it still wont idle. no vacuum leaks anywhere, and with map sensor unhooked, it runs great. any ideas
Old 10-24-2012, 10:28 AM
The mostly problem is an out of spec adjsutment or failure of the Idle Air Actuator (IAC).
Bogie
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 18 03-23-2012 05:29 PM
Idle problem with 1952 chevy 216 idle Haulin327 Engine 1 12-19-2007 06:40 PM
1981 Gm 3.6 V6 Rough Idle And High Idle nomaddaddy Engine 1 11-15-2007 09:49 PM
BG/BC Rich Idle & Idle Air Bleeds/IFR 68NovaSS Engine 3 11-10-2006 11:36 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
