no juice - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2004, 02:58 AM
New Member
no juice
hi guys i just dropped a 68' 289 in a 66 mustang and i am all GM this is the first mustang i've done an engine swap on and i am lost.... i got it all hooked up but for some odd reason i'm not having any juice anywhere.... i checked all of the wires in the ignition and the wires by the selenoid, grounds, and fuses.... dose anybody have any idea what's goin on here?
thanks
Derreck
Old 09-26-2004, 03:49 AM
docvette's Avatar
Wiki Edits: 12
Link
Doc here
Look for an unhooked or blown Fusible link...should be around the solenoid main cable area...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-29-2004, 01:24 PM
New Member
i already looked.... i was thinking about a dead short but i'm still trying to figger out where that would be thanks for the reply doc
Derreck
Old 09-29-2004, 03:07 PM
docvette's Avatar
Wiki Edits: 12
Ground
Doc here
A dead short would produce a massive spark when you tried to hook up the battery...
Not A Ford guy at all, but I think Ford may have used Fusible links on ground too...Check for that.
Also Make sure your ground goes from the Battery to the Starter housing or Block close by, then run another Battery ground Cable from that ground to the Frame.
To test run a Ground from the battery to the area of your fuse box. Turn the key on and with a meter check ANY fuse to the ground wire, If you get a read, your missing ground.
To test for power, just move your wire over to The + side of the battery, and the terminal marked BATT on the fusebox, if everything works as advertised, your missing power (fusible link)
Doc
Innovations
Old 09-30-2004, 12:11 PM
New Member
thanks alot doc i'll try that when i get home from school lol
Derreck
