Doc here,
A bad alternator can cause a battery to discharge beyond the point of return..if it (the battery is bad enough).. Lack of DC power to the Car is generally caused by:
Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Does the rest of your electrical system seem to work ok? If you're only having issues with lighting then I'd suspect the head light switch or maybe a blown fuse (or fuses). Do you have tail lights and no brake lights or no lights back there at all?
As far as the bald alternator goes, I don't think I've ever seen one that actually had hair...
Wouldn't this fit in, in the electrical forum?
Doc here,
Does it start? Have Wipers? Have Heater? horn works? Have a Radio? Your first post leads the reader to believe that the car is without power everywhere..if this is different, then you have a different set of problems.. If just the lights are not working, check each fuse first.. Then check the headlight switch. Check the column plug at the bottom of the steering column plug for bad, or dirty pins or loose fit. Doc
| GM courtesy lights | 78 monte | Electrical | 13 | 11-25-2009 05:48 PM |
| voltage to tail lights vs brake lights? | stratt134 | Electrical | 12 | 06-10-2006 06:51 PM |
| Wiring Tail Lights & Turn Signals | horvath | Electrical | 15 | 04-30-2003 05:04 AM |
| Back Up Lights - how to choose? | horvath | Body - Exterior | 6 | 03-04-2003 03:20 PM |
| my newborn crapped his die-dees: l.e.d lights all blew up | bullheimer | Electrical | 4 | 08-16-2002 08:44 AM |
