no lights after eng work - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2011, 05:06 PM
where did my lights go? Can anyone help me I have a 83 c-10 with a 350eng and a 350 tranny. I just got finished doing a lot of work from water pump,harmonic bal motor mounts rad ......and now I have no head lights can someone help? thanks......
Old 06-11-2011, 09:26 PM
Most common reasons for complete loss of power:
- loose cable connection at the starter. This is where the main power is connected for the truck.
- Fried fusible link. It may be the end where it connects to the junction on the firewall next to the brake booster. It could also be the point where it connects to the starter.
If its only the headlights that are off (other power is on), then its probably the headlight switch itself or the dimmer switch on the floor.
Bruce
Old 06-12-2011, 08:10 AM
Hoptup32's Avatar
The headlights may have been grounded to the radiator core support. Did you have any wires that needed to be unbolted and pulled out of the way when working with the radiator?
Old 06-12-2011, 01:31 PM
T-bucket23's Avatar
Wiki Edits: 26
You need to check for power at the lights with a test light with the other end clipped to the neg battery terminal. If you have power your ground is missing somewhere, most likely around the radiator. If there is no power I would check for a blown fusible link or a broken wire. Most likely something around the radiator as that was where you were working.
Could be the switch but I always go back to what was done last, usually you will find the issue.
Chet
signal lights dont work.... sexypizzaman Electrical 14 12-02-2008 08:44 PM
only my lights work....help! 6speedwagon Electrical 6 05-27-2005 07:04 PM
Lights don't work USMCDCC Electrical 8 04-25-2003 08:47 PM
Tail Lights Won't work! fireschenie Electrical 7 01-11-2003 08:10 PM
Help! dash lights and buzzers won't work. shortymac83 Electrical 7 11-24-2002 05:20 AM
