did you upgrade anything else with the cam? or is it all stock?
With exaust headers, heads, and an intake you will get the effect you desire. Also, make sure your valve springs can handle the lift of the cam, that's a pretty big lift and some springs may bind. |
What RPM do you have the car idling at?
I have a solid roller in a chevelle thats the same way, 242 duration @.50 .607 lift w/ 1.6 rockers..but alot of its in the lash, once I finaly figured how to set them right, its got a nice rumble to it..I used the crane method..
lobe separations 112.. must be it.... yeah everything was upgraded with the cam.. holley aluminum heads, 2.02/1.94 valve the tri spring valves all the goodies.. would the cam timing effect it any??
