Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No low end torque
Old 09-04-2005, 06:22 AM
shine's Avatar
shine shine is online now
SPI Thug
Last journal entry: some progress
you have a bracket motor. your power range is going to be 3k to 6500. getting a tune for the street is going to be tuff. big cam, big valves big carb = rpm. your best bet will be a small carb with a lean tune for street use. from there you will have to decide how much of one to give up for the other. street or strip. take your time and you'll get there. it's just really tuff to tune this type of set up for the street. see if you can borrow a 650 to start with and work up to what you want. most of your driving will be from idle to 4k. tune for that. you can always carry a big carb set up for play in the trunk good luck
