NO movement - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2006, 02:50 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
NO movement
I have a Turbo 400 trans. stock converter. I believe I overfilled it and I was getting fluid leaks. Tranny quit leaking fluid after a few startups (car not driven on street, just in and out of paint shop and garage). Car has driven fine. Went to pull it out of garage yesterday and car went three feet and quit moving, no forward or reverse. Checked fluid (cold) and it showed low! I figure that was why it quit moving. What is the proper way to add fluid to a Turbo 400 so you get it right and don't overfill or underfill? Thanks in advance.
Old 08-14-2006, 10:45 AM
Proper way to check fluid is with the car at opperating temp and in park. Remember that trannys take fluid in ounces not quarts. This is what I have always been tought and I could be wrong so someone correct me on this if need be.
Old 08-14-2006, 11:16 AM
I know I dumped quarts in that tranny when I first got it because I believe the converter was empty. I am totally ignorant when it comes to automatic trannies. I think I will drain the pan and start over. How do you drain the converter? Is there a plug on it? Do you then start the car and add fluid and the pump will make sure the converter gets filled? I feel like an idiot for asking these questions but I just don't want to screw this thing up. Thanks in advance.
Old 08-14-2006, 12:07 PM
STUPID is as STUPID does...
I doubt it was overfilled to begin with. If the convertor was empty, all of the fluid has gone to fill it. You need to add more to bring the trans up to fill level. You don't need to start over... Just finish what you started... And you will probably see the leaks come back once you get it filled...
Here is a fluid fill chart from TCI... It takes a few "quarts" to fill up a th400...
http://www.tciauto.com/tech_info/fluid_capacity.htm
Mark
Old 08-14-2006, 12:09 PM
Just start your car and let it get up to running temp, check it in park and add accordingly. Dont jsut drain your tranny and start over. The only way to drain the converter is to pull the trans and take the converter out, atleast this is the only way I know of?
Old 08-14-2006, 01:14 PM
All right. Thanks guys. I tell you what, I am so tired of this car doing this to me! I was fully prepared to take the wife and kids around the block and this happens! I love hotrodding!
little movement in reverse gm_71chevelle Transmission - Rearend 2 02-20-2006 04:30 PM
Th350 Help No Movement 83_Monte_SS Transmission - Rearend 6 09-24-2005 05:57 PM
The so called "rat rod" movement... Nightfire Hotrodders' Lounge 16 06-27-2005 10:28 AM
How much side to side movement does a rear axle make STATUTORY GRAPE Suspension - Brakes - Steering 9 11-23-2004 06:23 PM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 07:36 AM
