No O/D.. slips in 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2003, 08:12 AM
WDK WDK is offline
Post No O/D.. slips in 1st
I have an 87 Suburban 4X4 that has a Tx problem. Was driving it the other day and with the shifter in O/D..all of a sudden I had nothing..just like it was in neutral. When you put it in reverse it is normal. In 1,2,3 it "shudders" when taking off even at low throttle pressure. Once it gets moving it shifts OK except that I still have no O/D. It is a Mr. Goodwrench tx that has about 24K on it but the 36 months has expired. Any ideas? TIA
Old 03-10-2003, 06:22 PM
WDK WDK is offline
Post
Just did a filter and fluid change on the above transmission. Nothing found in the pan and the fluid was clean. Replaced filter and fluid with no change in performance. I suspect the converter is bad. Any ideas?
Old 03-10-2003, 07:15 PM
airworld2's Avatar
Post
sorry to say time to pull the trans out forward sprag or forward plates just a guesss without test drive
airworld2
Old 03-10-2003, 07:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
WDk, sounds like the tranny needs to come out.
The converter is not your problem. If the converter was the problem the tranny would not function well in reverse.
As mentioned the tranny is probably broken in the forward sprag/friction area of the input drum. The over-run frictions are probably transfering most of the power and they are small frictions.
Tony
[ March 10, 2003: Message edited by: Crosley ]</p>
Old 03-11-2003, 12:55 PM
WDK WDK is offline
Post
Would a pressure test be of any help? I don't even know if it has test ports but I do have the equipment to check pressures from my old days of working on forklifts.
Old 03-11-2003, 01:09 PM
deuce_454's Avatar
Post
the pressure port is 4 inches above the shift lever. and it is needed when adjusting TV cable tension, see www.700r4.com for detailed instructions
i can only recomend their transmissions, and the service is outstanding
Old 03-11-2003, 07:22 PM
airworld2's Avatar
Post
forget the small stuff this trouble is inside trans,you can waste your time if you want to know what line pressure is but, money well spent remove trans send it out to a shop in your area
airworld2
Old 03-12-2003, 08:32 PM
Post
before i pulled the trans i would try lucos trans fluid. my 350 trans would not shift or move with a new stall converter and a freshly rebuilt trans, come to find out the valve body was stuck
Old 03-13-2003, 06:49 PM
airworld2's Avatar
Post
tranmissions is what I do day in and day out you have inside trouble, since 78 thats been my job is to fix transmission trouble. you need a rebuild no easy fix here, sorry cant give you better news.
airworld2
