No oil pressure on a 1970 olds 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2012, 12:09 AM
I have a 1970 olds 455 that I can't get oil to the heads I changed oil pump to a high volume pump.can someone please help
Old 01-08-2012, 03:54 PM
Are the lifters clacking from lack of oil? If not, your push rods are probably plugged.
Have you put an actual mechanical gauge on the oil pressure port at the front of the engine to check pressure? wouldnt be a bad idea.
Old 01-14-2012, 12:01 AM
1970 olds 455 not getting oil to the heads
Yes I got a gauge on it. When I spin the oil pump were the distributor goes I can see slot of oil flowing through
Old 01-14-2012, 12:13 AM
Did you prime the pump?
Old 01-14-2012, 11:38 AM
Spin the oil pump drive-shaft counter-clockwise to prime the motor.
whats your oil pressure reading?
Do you have the proper plug in the rear oil passage(its inside the motor, behind one of the plug/cap inside the bellhousing area.
engine 1970 455 olds 56oldsmobile88 Hotrodding Basics 1 12-30-2011 05:38 AM
1970 Olds 350 - Inspection Advice dsolomon Engine 21 02-08-2011 11:07 AM
olds buick 231 p/s pump onto an olds v-8? fast68 Engine 3 03-04-2010 07:07 PM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 04:35 PM
1970 El Camino SS Oil Pressure Gauge retrotruckparts Electrical 2 10-19-2005 08:08 PM
