No oil pressure, revisited - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2004, 04:59 PM
New Member
Last journal entry: Latest pics
Ok, I found the problem with the oil pressure. I pulled the front of the motor off and the three small holes behind the cam gear are unplugged.
My question is this, do they all get plugged or just two, or ????
Thanks for any assistance.
Bob
Old 07-14-2004, 05:06 PM
BOBCRMAN@aol.com's Avatar
Plug all three.
Old 07-14-2004, 06:20 PM
New Member
Originally posted by BOBCRMAN@aol.com
Plug all three.
Thanks.
Ok, I plugged all the holes, spun the oil pump again and got 30 lbs on the gauge. I got oil up to the rockers on the whole left bank but didn't get any oil up on the right bank.
Whats up with that. Could it be that the drill just didn't spin it fast enough?? Any ideas. Thanks.
Bob
Old 07-14-2004, 07:04 PM
If you are spinning the pump without a distrib housing in the block you will have very little oil to one side as the dist body acts as a plug to a large oil leak..
Old 07-14-2004, 10:26 PM
[QUOTE]Originally posted by BOBCRMAN@aol.com
If you are spinning the pump without a distrib housing in the block you will have very little oil to one side as the dist body acts as a plug to a large oil leak.. [/QUOTE
Very true, Some pre-oilers are just a shaft while others will have a plug that the shaft goes through that will extend deep enough to seal the galleys and allow oil flow to all parts of the engine.
Old 07-15-2004, 04:01 AM
New Member
[QUOTE]Originally posted by tresi
Ok, very good. Thanks for the info. I appreciate it.
Bob
