no oil in top end of pontiac 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2010, 11:55 AM
recently bent pushrod on my pontiac 400 replaced it and fired it up without valve cover on it (30 seconds) and didnt see any oil.factory gauge is showing normal pressure but not getting any of it up top.now i've heard it takes awhile to buildup but didnt think that it should take that long??
Old 02-08-2010, 05:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You would expect to see oil out of the p-rods by 30 seconds.
Where is the oil pressure gage sender/fitting located? Is the valve train noisy?
Old 02-09-2010, 09:56 AM
Thanks for responce cobalt327. The valve train wasnt noisy and there was oil puddled up on head. I am not sure were sender fitting is located but i will check that tonight.
Old 02-09-2010, 12:16 PM
fast68's Avatar
likes chevy trucks & boobies
maybe its losing oil around the distributor housing in the block?
just an idea
i dont know
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 07:17 PM
Need help,Pontiac 400 BEN24 Engine 4 09-05-2007 02:26 PM
400 Small Block oil problems bac6772 Engine 40 07-05-2007 01:49 PM
Trick Flow top end RCastle Engine 4 01-08-2005 09:19 PM
