Artificial Intelligence is no match for Natural Stupidity Chet |
late lastnight i rebled them with a buddy and still the same thing
Brakes
May have to bench bleed the master.
Also, if you somehow (not that I have ever done this ) got one or more of the wheel cly installed wrong, you may have the situation where the bleeder is not at the very TOP of the cyl - so it can now bleed fluid while there is still air in the cyl. Easy to reverse them L to right on some systems (results in the cyl being upside down, but can still be installed) , impossible to do on others, but just a thot.
You have to get the prop valve re centered so the Brake warning light is out to bleed the system or you will only have one set of brakes working, and you wont be able to bleed the blocked off system.
I have good luck gravity bleeding systems almost 100 % of the time. Sounds like a master cylinder problem If I were to guess. |
| Relationship between Gas Pedal and Brake Pedal | 35WINDOW | General Rodding Tech | 12 | 01-11-2012 01:35 PM |
| Pedal car / go kart Rod | udu56 | Hotrodders' Lounge | 1 | 10-24-2006 07:31 AM |
| gas pedal | mayday3045 | Interior | 9 | 04-16-2006 08:01 PM |
| possible hard pedal | blackbeard | Suspension - Brakes - Steering | 16 | 01-10-2005 06:23 AM |
| clutch pedal | tony00 | Transmission - Rearend | 1 | 12-14-2004 06:55 AM |
