no pedal
i just replaced the the brake shoes all the way around replaced the wheel cylinders and all new lines and harware kit bled the brakes and when i start the car my brake light is on and there is hardly any pedal what could it be i also replaced the master cly back in april of 2011
Cole :pimp: |
whats the proper drag ajustment and they are drum to drum
thanks i will readust and rebleed and see what happens
Cole :pimp: |
no pedal
Happy new year Cole, Matt, and 71 Nova. Bob |
i was in bed by 10:00 :thumbup: |
after reajusting and rebleeding it is a little bit better not where i would like it to be at but it does stop
double check the shoe adj on all 4 corners
and just a note, when bleeding you should start at the break that is farthest away but you may have already known that :thumbup: also, make shure there are no leaks on all that new stuff :pain: |
I would be willing to be you still have air in the lines. Can you explain your bleeding procedure. |
Cole :pimp: |
Cole :pimp: |
i used a power bleeder
| All times are GMT -6. The time now is 06:50 AM. |
