no pedal
i just replaced the the brake shoes all the way around replaced the wheel cylinders and all new lines and harware kit bled the brakes and when i start the car my brake light is on and there is hardly any pedal what could it be i also replaced the master cly back in april of 2011
Cole
whats the proper drag ajustment and they are drum to drum
thanks i will readust and rebleed and see what happens
Cole
i was in bed by 10:00 |
after reajusting and rebleeding it is a little bit better not where i would like it to be at but it does stop
double check the shoe adj on all 4 corners
and just a note, when bleeding you should start at the break that is farthest away but you may have already known that also, make shure there are no leaks on all that new stuff
I would be willing to be you still have air in the lines. Can you explain your bleeding procedure.
Artificial Intelligence is no match for Natural Stupidity Chet |
Cole
Cole
i used a power bleeder
| Relationship between Gas Pedal and Brake Pedal | 35WINDOW | General Rodding Tech | 12 | 01-11-2012 01:35 PM |
| Pedal car / go kart Rod | udu56 | Hotrodders' Lounge | 1 | 10-24-2006 07:31 AM |
| gas pedal | mayday3045 | Interior | 9 | 04-16-2006 08:01 PM |
| possible hard pedal | blackbeard | Suspension - Brakes - Steering | 16 | 01-10-2005 06:23 AM |
| clutch pedal | tony00 | Transmission - Rearend | 1 | 12-14-2004 06:55 AM |
