No pedal pressure after power brake install - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2005, 09:23 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I recently installed a powerbrake booster and master cylinder pulled off a 75? Ford truck with 4 drums all the way around just like mine. After bench bleeding the mc and installing it on the vehicle I have no pedal pressure with it running, I checked the pushrod length it is right on spec. The booster does not make any kind of hissing noise with the pedal applied, could the MC be bad? Is there anyway to test to see which one could be at fault? Thanks
Old 05-17-2005, 10:46 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
welcome to the world of chitty ford brakes bro. I can't wait til i get to park mine and swap i beams for discs. and then i get to buy new wheels. damn i love our old trucks.
I'd check to see if your getting pressure out the front and rear ports off the mc. if so, then are you getting pressure to all four wheels? any fluid out on bleeding? any pressure on pumping the pedal?
Kultulz linked me a great spread sheet awhile back, let me see if i can find it......
Old 05-17-2005, 10:48 PM
http://www.ucx.com/flowchart.pdf <---- spread sheet.
http://www.911brakes.com/trouble.htm
http://www.911brakes.com/ <--- main page.
Old 05-18-2005, 07:19 AM
Thanks larry, I'll have to give those a try.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
No Brake Pressure....help Steve-0321 Suspension - Brakes - Steering 31 06-20-2004 10:13 PM
brake bleeding with pressure 73chevyhelp Suspension - Brakes - Steering 8 05-20-2004 07:55 PM
Manual brake pedal travel jpd37 Suspension - Brakes - Steering 8 05-22-2003 12:17 AM
