No Power - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2010, 12:42 PM
No Power
Ok 79 350 engine just put a timing chain and gears on a couple days ago, retimed the engine and it ran fine. two days later I started it and it idled fine and everything but the second i put it in gear and give it gas it dies. once i get going i give it gas and it just completly cuts out, like i turned the key off or something, but let off and it runs fine. I can floor it and it does the same thing but give it a few seconds and it will take off but only when i floor it.anyone have ideas?
Old 05-11-2010, 02:34 PM
Have you checked the accelerator pump squirt? Whats the timing set at?
Is it a stock engine?
ssmonty
Old 05-12-2010, 12:52 PM
its a stock engine timing set at o* factory settings i think its a vacume leak now i took the air cleaner off and reved it to a fast idle it started cutting out really bad again and you can hear it suck air like crazy. i held the damper on my front two barrles down and it ran perfect
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 10:12 AM
chevy 350 jimang22 Engine 4 07-14-2007 04:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 11:09 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-24-2004 12:38 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
