no power - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2012, 12:12 PM
no power
I have a1990 firebird 305 tpi stock motor runs terrible at low idle clears up at 2000 rpm but has no power under load timeing chain was streched replaced compression test came back good 145 to 155 all cylinders adjusted valves and timeing new plugs wires cap and rotor all acell no cat or polution pump good fuel pressure help
Old 02-04-2012, 06:53 PM
T-bucket23's Avatar
Wiki Edits: 26
I would look for vacuum leaks to start with
Chet
Old 02-04-2012, 07:57 PM
gonzo08383's Avatar
Last journal entry: brakes
sounds like vacuum. massive vacuum leak. power brakes acting a lil weak?
Old 02-04-2012, 08:07 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
is '90 tpi
speed den or mass airflow
Old 02-05-2012, 06:08 AM
I should have mentioned checked for vacume leaks cant find any so far smoke tested sorta used starter fluid cant find anything checked brake vacume boost ok new distributor ignition module doesnt have mas has a map changed got a code 33 and 22 map sensor bad and low voltage to tpi map can beo to low do to vacume checed all grounds and relays regarding tpi ohm tested tpi no dead spots seems good fuel pressure and fuel pump good can this have anything to do factory alarm or pass key bought it 8 months ago when i first looked at it i opened the door to check it out and an alarm went off there was nobody home so when i came back to here it run and buy it women said it had no alarm that she knew of i should mention car ran good when i bought blew had gasket 2 months later wasnt beating it car hadnt been driven much for 3 years gasket blew out on drivers cide rear cylinder between cylinder and water port checked all cylinders and heads for cracks gouges before putting it back together didnt over heat engine likei said compression great also car had msd fireball ignition coil setup that was acting funny puled it went back to stock this is my 17 year old kids car doesnt need to hurt himself yet
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
67 nova power sterring not power assist? turbonova Suspension - Brakes - Steering 6 12-20-2004 06:52 PM
Power or non-power steering is the question RAW Suspension - Brakes - Steering 2 09-23-2003 05:32 AM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 09:49 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
