No power - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 04:27 PM
New Member
Post No power
I have a 78 model 305 with hei, offenhauser 4 barrel intake, holley 600cfm carb and a rv cam, it has no power. I thought it was the timing so i checked it and it is set at about 7 degrees retarded. and if i get on it to much then it will pop back through the carb. i have no idea what the problem is and would appreciate any help. thanks.
Old 12-17-2002, 04:33 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
I think you just answered your own question, Set timming to 10 advanced and test drive.
Old 12-17-2002, 04:45 PM
Post
yes you are way to retarded set intial around 10 and check the total 35 is usually a good number.
Old 12-17-2002, 11:13 PM
New Member
Post
dont retard it as much and make sure not to blow your power vlve out of your holly by backfiring threw it good luck <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 12-17-2002, 11:55 PM
E.T. divided by $ spent= Speed
Post
Crank as much advance as you can without detonation.
Old 12-18-2002, 09:11 AM
Post
i had the same problem on sbc i read the cam sheet wrong and i set mine at only 3 deg re dont know why i even thought that it would be that but i did when i changed it to about 10 to 15 deg initial it made a world of difference
