Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no power/backfire through carb/timing? 355 build
Old 11-17-2010, 05:46 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
A few things to check,
Have you looked at the exhaust to be sure there are no restrictions. This
can kill power.
Check the fuel pressure with a gauge
You say the vacuum advance brought it from 17* to 50* at idle, this is not
right.
I would expect to see more vacuum at idle with that setup, a leak or a
plugged exhaust or late timing will cause low vacuum readings.
Check the voltage at the HEI, it should be battery voltage. That car
originally had a resistor wire feeding the coil and the running voltage would
only be 9-10 volts. This will reak havoc on an HEI.
Chet
