No Power To Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2012, 07:30 AM
wrb36usa's Avatar
No Power To Brakes
I bought a '49 Willys Street Rod that has a '75 Mustang II manual front end (Discs brakes) & a '78 Chevy Nova 10 bolt rear (Drum brakes). When the brake was applied it would throw you through the windshield. To correct this problem, I have just replaced the 11 inch brake booster and 1-1/16 inch master cylinder that had an adjustable proportioning valve, (which did not seem to work).
I installed a new chrome corvette style master cylinder and 7 inch booster with a GM preset proportioning (combination) valve, (the booster was also in the way of the valve covers).
The proportioning valve was stuck, but I resolved that problem with the help of some of you guys.
Now, I can not stop the car unless I really stand on the brake. It is worse than having manual brakes. Can anyone help with this new problem?
Thanks
Old 10-26-2012, 10:34 AM
Faith - Respect - Trust
Without having the car in front of me it's a little hard to be precise on a diagnoses.. Hard pedal, no brakes could be a vacuum problem to the booster. That's the first thing that popped into my head.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
wrb36usa (10-26-2012)
Old 10-26-2012, 06:22 PM
wrb36usa's Avatar
Thanks Ray,
I am thinking the same thing. Will borrow a vacuum gauge and see if there is a leak or something.
Old 10-26-2012, 06:39 PM
Good luck with that...it usually is a vacuum problem and not too difficult ot expensive a fix.
Ray
wrb36usa (10-29-2012)
Power Brakes to Munual Brakes Dennis78B Suspension - Brakes - Steering 6 06-06-2012 04:49 AM
Power Brakes feel like Manual Brakes kbuhagiar Suspension - Brakes - Steering 13 09-10-2010 03:02 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 09:49 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
