No Power from Coil to Distributor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-11-2010, 07:39 AM
LATECH's Avatar
Since it ran before you tuned it I would suspect that you did something incorrectly when installing the points. Sounds like they are not set right OR you have the connection made wrong at them.I would check your work over to be sure. There isnt much sense in spending more money and putting in an HEI as The thing probably ran good with the points before it quit.You would not notice any difference in performance most likely, just a lighter wallet.
Points are pretty simple once you figure it out. Besides, you just spent all that spare change on the parts and installed them,no sense rippin them out to make more work at more exspense. Just my opinion.
Read Mr T Buckets article on how to points. I think you will be able to get r done if you do.
  #17 (permalink)
Old 12-11-2010, 09:05 PM
Got it!!!
First of guys, thank you very much for your help. Since I first discovered this forum, I've noticed that you guys are the most knowledgeable people I've come across when compared to all the other forums I participate in.
Taking your advice, I went back and adjusted my points using a business card and the truck started right up! Purrs like a kitten (with open ram's horn manifolds).
I do have to mention something that has baffled me, though. Before I figured out the points thing, I swapped the wires on the small posts on the starter solenoid. I put the yellow wire on the "S" terminal nearest the block and the larger gauge purple wire on the "R" terminal nearest the frame as a couple of you suggested. I tried to start it and nothing! I had figured I'd initially hooked them up right because there are several diagrams floating around the net showing that I had done it right. I've only ever messed around with starters with the "R" and "S". Is the "I" the same as the "S"?
Thanks again, folks.
  #18 (permalink)
Old 12-12-2010, 07:07 AM
LATECH's Avatar
Well I would have thought the I terminal fed the ignition, not sure about the R thing. I usuaaly just change a starter and since I havent even rebuilt one myself for quite a while I dont clearly recall.The S should be for start.
If it was made in china maybe it means sukiyaki and rice, hell its hard to tell.
I do know the purple one energizes the solenoid and on a SB chev it goes furthest from the engine, if it were on a pontiac (like mine) it goes closest to the engine as the starter is on the opposite side of the motor.
  #19 (permalink)
Old 12-12-2010, 01:00 PM
T-bucket23's Avatar
Wiki Edits: 26
I have seen the r terminal on some starters. The s is always the start terminal and takes the heavy purple or pink wire.
If you are going to run points you should get a feeler gauge or even better see if you can find someone with a dwell meter. Point gap should be 17-19 and dwell should be 28-32. If it is an original chevy cap, it should have the little door do you can adjust the dwell with it running. Takes an allen wrench, 1/8 if I remember correctly.
The nice one nice thing about points is you can almost always clean or adjust on the side of the road. Usually when electronic ignition dies you are calling AAA. A quality set of points installed correctly with the right condenser will last up to 15K miles with no trouble. Be sure you put a small dab of lube on the cam in the distributor to keep the point block from wearing. It only required a dab and use should use the lube that came with the points.
Chet
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Olds Ciera SL Spark Coil... awbazar Electrical 2 09-03-2010 03:11 PM
Wiring an Accel breakerless ignition distributor jomichael Electrical 4 05-07-2009 02:41 PM
Remote coil distributor Siggy_Freud Engine 4 11-18-2004 02:17 PM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 12:07 PM
