Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No power from distributor to spark plugs...
Old 09-10-2012, 02:34 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
Are you using some kind of spark tester to determine if there is spark? If not, get one they are cheap. Use the in-line spark gap type as opposed to neon.
Also open the distributor and see if everything is in place.
Make sure the rotor turns when cranking the starter.
A new distributor could be bad, not likely but it happens.
Possibly call Petronics.
vicrod
