no power to fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2009, 12:16 PM
I have a 1995 chevy lt1 in 34 master coupe. It was running fine than I stopped and fueled up, than started it. It ran for 30 seconds than died. The fuel pump is not coming on. I can run a wire directly to it and it comes on. the fuse is good. Could the computer have went bad?
Old 11-29-2009, 12:42 PM
ericnova72's Avatar
More for Less Racer
Isn't there a relay between the computer and the pump?? The computer doesn't have the amp rating high enough to run a high load device like the pump directly, it will burn up the computer. The computer triggers the relay, which runs the pump.
Old 11-29-2009, 04:23 PM
There should be two circuits that power the pump. The computer runs the pump for about two seconds through a relay when you first crank the starter. This primes the injectors. Once the oil pressure in the engine comes up, a separate oil pressure switch closes and completes the fuel pump circuit independent of the computer. If the pump does not come on when you first crank the engine, check the relay.
Old 11-29-2009, 04:30 PM
468c-10's Avatar
468c-10
I had the same prob with my 1990 truck. I had a loose ground check an see if you have power at the relay when you turn on your switch
Old 11-30-2009, 07:27 AM
Thank you for the suggestions/info. I will check these out and let you know.
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
Electric fuel pump shut-off mur39 Electrical 22 03-05-2007 05:48 PM
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 06:00 PM
Troubleshooting Fuel Pump Power on 87' Corvette edge Electrical 1 07-02-2006 06:12 PM
vapor lock, sbc, hot fuel pump Walker Engine 1 07-19-2004 10:31 PM
