no power to fuse block?
i am still chasing electrical gremlins and need help once again.
here is the problem, i have no power to fuse block. have positive battery cable run to starter. smaller guage wire from same starter post to to screw lug on back of alternator (have power there) short wire going to plug in connection on alt (power on that wire) the other wire coming out of eplug on alt has no power coming out of it no matter if key is on or off. is this even the right place too look or does power come from somwhere else (there is a terminal block under fender next to batt with power wire connected to it) any help will be greatly appreciated thanks wayne |
This may help you out >> http://www.madelectrical.com/electri...evymain1.shtml the main power runs thru the Horn Relay on most of these cars/trucks. The Fusible Link may be burnt.
it should also have a bigger wire from the starter 2 the fusebox
Chances are, the accessory wire (smaller red wire from battery/starter) is broken somewhere in the harness....If I remember correctly there is a joint in the harness just behind the distributor...I have seen them come apart there
Ontario Rodders |
| fuse for relay power? | dar130 | Electrical | 4 | 03-28-2011 08:34 AM |
| No power from "BAT" terminal on fuse block | for3300 | Electrical | 2 | 07-16-2010 06:17 PM |
| NO power to fuse panel | slider in wa | Electrical | 10 | 08-26-2008 11:46 AM |
| Problem with power to the fuse box | agent spliff | Electrical | 2 | 03-12-2007 04:40 PM |
| Fuse Block | Nic1979 | Electrical | 8 | 08-09-2005 01:21 AM |
