NO power to fuse panel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2008, 12:31 PM
slider in wa's Avatar
Slider in Wa.
I hope someone works on 1988 cheverolet c1500 pickups. I have been through the knowledge base, and searched on this and other sites. I have 13volts at the battery clean connections, all fusable links check good. Grounds are good. I have no power to the fuse block. NV 4500 trans with no power to what i think is netural safety switch.
I pulled the ign switch fron under the collumn, (Not the key) I disconnected the wires and have no power to any wires going into the ign switch.
Please advise me if you can and thank you so much.
Old 08-21-2008, 12:37 PM
Check the bulk head connetor. More than likely it has either melted the connector or the terminal. It should be the large red wire going throught the connector.
Old 08-21-2008, 02:32 PM
Slider in Wa.
I disconnected and reconnected the fuse block. Now i have power back, but nothing to the starter. Thanks so far. Have a great day.
Old 08-21-2008, 02:40 PM
Check power in and out of the ignition switch. Red going in and the purple is the start signal going out. Then check the neutral safety switch while holding the key in start position. If you were having connection problems then it it quite possible it burned up one of these switches.
Old 08-21-2008, 03:10 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Most fuse blocks are fed power from a fusible link coming off of the starter solenoid..(the same big lug that your positive battery cable hooks too). Check there..that fusible link could be burned out or you could just have a bad connection there.
Old 08-21-2008, 03:37 PM
T-bucket23's Avatar
Wiki Edits: 26
Since you were able to get power by disconnecting and re-connecting you most likely have some corroded connections. I would pull it back off and see what the problem is. That is prime conditions for an electrical fire !!!!!!
Chet
Old 08-21-2008, 04:38 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
There should be 2 fusable links on the big lug of the starter check them.
Make sure you have a "ground triangle".
good ground to the frame ,body & engine.
Check for dirty Battery terminals , wires & connections.
Make sure the bolt going into the fuse block is tight.
R
"SlowRide66"
"Illegitimis non carborundum"
Old 08-22-2008, 12:45 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Do you have a wiring diagram for the truck? Have you followed the wires and verified continuity to the 'start circuit'?
Old 08-22-2008, 02:09 PM
Rob Keller's Avatar
Wiki Edits: 38
Auto Zombie Schematics
R
"SlowRide66"
Old 08-26-2008, 11:31 AM
Slider in Wa.
Done done it!
Thanks one and all. After 3 days i found the ign switch do under dash was bad. I guess i did not beleive it couldd go bad setting in the yard over night. Thanks again
Old 08-26-2008, 11:46 AM
Lost in the 60's
Wiki Edits: 4
Glad you got it Slider.....thanks for telling us the fix.
fuse panel ssiefkes Electrical 2 10-23-2006 04:30 PM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
