no power getting to my ignition coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2009, 01:32 AM
when i turn my key to the start position i have power going to the ignition coil and the starter. i can hear the engine start to turn over. when i release the key and it goes to the on position the car shuts off. i don't have constant power going to the ignition coil to keep it running. where is this power supposed to be comming from?. i have the battery cable hooked up to the starter. i have the mail power supply going from the starter to the firewall and into the ignition switch. from the ignition switch there is the ignition wire going to the firewall and to the ignition coil (+) from the ignition coil (+) the starter wire going to the starter. i've tested my starter, and ignition coil; both are good. the ignition switch is brand new, along with the spark plugs. i know that i'm missing something small.... please help. thank you.
Old 08-01-2009, 09:36 PM
to any one else that is having a problem similar to the one that i had... check and double check the wires going/ coming from your starter. i had my wires in the wrong place. also check out:
http://jollyrodder.com/hot_rod_links...chematics.html
awesome wiring diagrams... that link is for chevy novas
1991 olds 88 coil pack check fumplet Engine 6 09-16-2006 08:12 AM
Ignition coil suspected of being faulty...how to test it? Steve-0321 Electrical 1 10-15-2005 04:40 AM
Ignition coil suspected of being faulty...how to test it? Steve-0321 Engine 3 10-15-2005 04:38 AM
Power Seats MI2600 Electrical 4 10-06-2005 04:55 AM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
