No power at key - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2012, 03:52 PM
jeffmc's Avatar
jeff mc
Last journal entry: 1941 Dodge Custom
No power at key
Hello All
First of all I finally got tags on my 41 dodge !! Been 6 years and being that I'm not a auto mechanic and not been a car guys for to long It been a struggle ..
Now to my problem.
I have a quick question,,Where would be the best place to start trouble shooting This?
I have power every place but when I turn the key it will not crank over . If I jump the starter poles it cranks, This is all gm stuff ,,motor,wire harness,steering column .Painless under dash harness.
This has been an off and on problem, I thought I had it fixed the last time .
So where would be the best place to start?
Jeff
Old 08-31-2012, 04:07 PM
jeffmc's Avatar
jeff mc
Me again
There is one more piece of the puzzle I think . Also the battery has to be at full charge before it will crank. I remember some one saying that there is a solenoid in the ignition system that will not let it crank if there is not enough power in the battery.Sound like kind fishy to me
I wrote the first post and it would not start ,walked over to the garage after and saw the battery charger at 100% and it started right up!!
Jeff
Old 08-31-2012, 08:45 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
basics, clean, tight
Most of the time these types of problems are simply a poor connection.
First thing, make sure both battery terminals are clean. Remove, clean with a wire brush or knife. Replace and tighten. Are the battery cables new? Replace.
vicrod
Old 09-01-2012, 04:38 AM
EOD Guy's Avatar
As Vic said, prob a loose connection, I fixed one last week...... dude said, he had to jumpstart it every time.... popped the hood, neg cable was so loose you could spin it on the post by finger press
turn the key fires right up let go of the key and nothin! jr19661966 Engine 7 11-05-2011 05:47 PM
Dave Marcus on the Power block Building turn key hot rods ChevyTruckGuy Hotrodders' Lounge 4 03-09-2010 02:07 PM
12 volt key on power source? lapersinger Engine 4 09-22-2008 05:58 PM
The Key to Lettering is? The Key Printing Body - Exterior 10 05-12-2007 01:52 PM
stuck key nikkicamaro Suspension - Brakes - Steering 1 01-05-2007 11:36 PM
