Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no rear brakes
Thread: no rear brakes
Old 04-06-2012, 12:13 PM
kleen56's Avatar
kleen56 kleen56 is offline
A couple of things... Is the MC from the corvette for drum or disc brakes? It makes a difference. If your running drum brakes in the rear and disc up front, you need the same for a MC because there is a big difference in brake pressure between drum and disc brakes. Secondly, try a mallet and hit the drum on the sides, not so hard that you break the drum but enough to dislodge whatever is frozen.
