Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no rear brakes
Thread: no rear brakes
Old 04-09-2012, 12:08 AM
MJS69's Avatar
MJS69 MJS69 is offline
Sounds like the proportioning valve to me.
Agreed....with front disk and rear drums, you probably have a combination valve....it needs to be recentered before it will bleed. Once you get it recentered, you will have to hold the pin on the passengers side of the valve in, or use a combination valve center stop that screws into the top of the valve where the brake warning light relay attaches....
