just a question, did you just put the manual master cyl on. i assume the car was originally power brakes, if so , did you change the push rod. best way to check push rod adjustment, with master cyl empty, look down into the ports, if they are blocked off, the rod is out of adjustment. you should also take the lines off the master, when you get it bleeding properly there, then it should be good at the back. just saves alot of trips back and forth. keep us posted.
