No Rear Brakes.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2009, 12:54 AM
Datsun SBC/BBC/LSx Guru
No Rear Brakes....
Hey guys, I am just wrapping up my '69 C10 truck after being apart after swapping to front disc brakes, drop spindles, power booster/master cylinder, and 4 corner air-ride conversion. The rear drums were untouched (for the moment).
Anyway, I had the truck in the air to bleed the brakes and after I was finished I started the truck and put it in drive to test everything while still off the ground. Well as my luck would have it, I have ZERO rear brakes, not even enough to stop the axle while off the ground. The front brakes work fine. I know I have fluid making it back there because I had plenty of brake fluid coming out of the bleeders when I was bleeding them.
Now I know the first question you guys would ask is if they were working BEFORE the swap, well to be honest, I don't know. I haven't really driven the truck since buying it and since it was a manual drum setup all the way around I can't be sure either way. I can tell you the braking was piss-poor compared to my '74 K5.
I've pulled both rear drums, the shoes and drums are great shape, and neither wheel cylinders are leaking, and just be sure I've adjusted both sides shoes to drag lightly on the drums.
My guess would of been the wheel cylinders, but I've never heard of them going bad without leaking, plus what's the odds that both would be bad at the same time?
So guys, I am eager to hear your ideas.
Thanks!!
Old 03-17-2009, 05:27 AM
did u bleed the rear ones too? maybe someone blocked those off with a small nail in each line so they could spin the tires easier. u said the shoes where like new, and the masters' weren't leaking.. so they must have not been used in a while.. check each fitting and the center brass connector... just my idea..ok u did bleed the rear ones the wheel cylinders could be frozen if u r getting plenty of fluid then its probably bypassing the guts of the thing
Old 03-17-2009, 05:41 AM
Last journal entry: 50 Ply wagon
You said you put a new master cylinder on. Did you bench bleed the master cylinder before you put in on? If you didn't, that may be the culprit.
Old 03-17-2009, 09:13 AM
Yup, bench bled.
Old 03-17-2009, 09:27 AM
Big Don's Avatar
Brake problem
If all is correct at the rear wheels then the only thing I can come up with is air trapped in the MC. To check for this problem remove MC cover and stroke the pedal SLOWLY and watch for a bubble as the fluid moves. If you see even a small bubble, then thats the trouble. Make sure the MC is level to the earth. Some GMs mount the MC to the firewall and sit out of level and are very difficult, no, impossible to bleed the lines to the rear until the MC is level to the earth. Try it. It won't cost anything but a little time.
Old 03-17-2009, 09:21 PM
S10 Racer's Avatar
http://www.warsprints.com
The wheel cylinder pistons may be froze up (rusted) inside and not really working. Even a froze up cylinder will appear to be bleeding when you open the bleeder valve but it's not working the pistons. Wheel cylinders are cheap and not worth rebuilding unless you have something rare. I would change the wheel cylinders and then re-bleed them and then they should work.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
1979 F250 Rear Brakes MrCoolDale Suspension - Brakes - Steering 1 07-14-2007 06:11 PM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
rear drum brakes oldcarguy85 Suspension - Brakes - Steering 3 01-08-2002 09:41 PM
