No reverse!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2003, 04:05 PM
Post No reverse!!!
383 stroker/th350 I have no reverse and it is real sluggish in drive. Help!!!
Old 02-26-2003, 06:09 PM
Post
rebuild time, dont know of any prolong, good luck.
Old 02-26-2003, 07:02 PM
BOBCRMAN@aol.com's Avatar
Post
your tranny is toast!
Old 03-05-2003, 11:35 AM
Post
rebuild it cause i have a turbo 350 and lost all forward gears just had reverse i drove home in reverse and rebuilt it the bands were streched out and the filter needed replaced so to save money do not buy a kit but rather find a shop to just get what you neeed sounds like the filter or bands on yours too hope that helped
Old 03-06-2003, 02:03 AM
senor_limpio's Avatar
The Dude
Post
If you're to the point where you're pulling the front pump, you might as well just finish the job. (That is, if you have the tools.)
Just my opinion.
Rock on!
-Seņor
Old 03-06-2003, 05:45 AM
5.0Towncar's Avatar
Post
TH350's are almost a dime a dozen. Get it rebuilt with the best parts you can find and get a shift kit....Est. rebuild+parts around 600 bucks or so. Steve
Old 03-10-2003, 08:04 AM
Post
Have you changed your trans filter? Most people never do. It should be done at least every 30,000 miles. I have had trans that would not even move and replaced the filter and then friied the tires off. In fact I have 3 cars now that I did this to and they are still going good. It would cost you about $20.00 to try it. This is not a large amount to try it.Good luck
