-   -   no reverse with a 350 transbrake tranny? (http://www.hotrodders.com/forum/no-reverse-350-transbrake-tranny-209771.html)
montezuma 12-03-2011 10:15 PM
Hey - I have a 350 transbrake transmission that will not go in reverse?? any suggestions what the problem my be
WDCreech 12-03-2011 10:38 PM
What does it do when you put the shifter in reverse and press the transbrake button? If nothing, there is a bad connection, or the solenoid is bad.
WDCreech 12-10-2011 07:11 PM
montezuma, did you ever get reverse to work, in your transmissin? If so, let us know what the problem was.
Bill
Crosley 12-10-2011 08:51 PM
Bill
member montezuma has not logged in since his post here.
:pimp:
WDCreech 12-10-2011 11:50 PM
Thanks, Crosley! It's typical that some ask a question and then never return to let us know if they've solved the problem.
