no reverse with a 350 transbrake tranny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2011, 09:15 PM
Hey - I have a 350 transbrake transmission that will not go in reverse?? any suggestions what the problem my be
Old 12-03-2011, 09:38 PM
WDCreech's Avatar
Grumpy Old Goat Herder
What does it do when you put the shifter in reverse and press the transbrake button? If nothing, there is a bad connection, or the solenoid is bad.
Old 12-10-2011, 06:11 PM
WDCreech's Avatar
montezuma, did you ever get reverse to work, in your transmissin? If so, let us know what the problem was.
Bill
Old 12-10-2011, 07:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Bill
member montezuma has not logged in since his post here.
Old 12-10-2011, 10:50 PM
WDCreech's Avatar
Thanks, Crosley! It's typical that some ask a question and then never return to let us know if they've solved the problem.
200-4r tranny wont go in reverse mr.g-body Transmission - Rearend 2 08-17-2010 06:06 PM
My tranny will not lock into Reverse strokedout Transmission - Rearend 0 10-20-2009 11:47 AM
350 Tranny Won't Reverse 70 Chevelle ss Transmission - Rearend 2 02-22-2007 05:20 PM
Tranny has no forward or reverse jon B Transmission - Rearend 4 04-15-2006 01:52 PM
GM T-5 tranny.....no reverse or fifth gear??? chevyelc81 Transmission - Rearend 2 01-07-2003 05:29 PM
