Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no reverse
Thread: no reverse
Old 05-19-2006, 03:01 PM
scrot's Avatar
scrot scrot is offline
Double, tripple check the tran fluid level. With fresh fluid, it can be very hard to see the correct level. If the fluid smears all over the dipstick as you pull it out, you might think you have it filled up, but you are in reality low.
