No reverse in 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2009, 04:31 PM
No reverse in 700r4
i have a 700r4 transmission which ive just got rebuilt it works fine except theres still no reverse the transmission suspose to be a 84 but the guy that rebuilt says that it has to be a 90 model because of the 5 solenoids and he says thats why it wont go into revers because it needs a computer to tell it to go in reverse please help
Old 03-08-2009, 06:11 PM
CrashFarmer2's Avatar
Dried up in the Drought! :(
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Hello and welcome! Your question would get more attention in the Transmission - Rearend forum.
Old 03-08-2009, 07:01 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving it there.
Old 03-08-2009, 09:49 PM
fast68's Avatar
likes chevy trucks & boobies
year of the trans is the first number small stamping code on a flat spot on the pan rail or on bellhousing outside flat edge
for example if it starts with 0 then its 1990
87 and up are the good ones and have an aux valve body inside the pan
87-93 or so are the good updated ones without computer control
all cars and truck and full size G series vans, and s-series blazers and pickups also\
some caprice and all vette ones are shorter length tail unique, about 1.5" or so shorter.
so watch out for that.
no reverse could be one of several issues,. internal linkage problem. or bad valve or valve seal in the valve body, or something else.
or was it actually built without reverse capability?
good luck
Old 03-08-2009, 10:33 PM
Wiki Edits: 85
700s do not have 5 solenoids. They only have one solenoid which fits into the pump near the valve body.
700r4 no overdrive reverse supercoop Transmission - Rearend 20 12-14-2008 11:16 AM
700R4 Rebuild/ No Reverse? 911carrera Transmission - Rearend 7 08-09-2008 11:44 PM
700R4 Noise in Reverse oldcarguy36 Transmission - Rearend 6 05-14-2008 05:39 PM
700r4 4x4 1989 reverse gear works half the time MuscleBlock81 Transmission - Rearend 3 08-22-2007 08:50 AM
