no reverse
I just rebuilt my 700 R4 and put a new 2500 stall converter.I went through all the gears when I filled it up,reverse grabbed at first but now,nothen,this hasn't been my first rebuild,but I cant figure it out,any Ideas?
no reverse
how is engine braking effect when downshifting 2nd to low?
my first thought on this would be popped out the snap ring holding low roller in place, low reverse clutch plates. if thats not it the only other thing I can think of is a cut sealing ring for reverse input drum but that will cause no reverse and still have engine braking 2nd to low gear. |
no reverse
I checked the fluid,it is good and as far as engine breaking,from 2 to 1,its great. when I first started it up reverse was the first gear I went too,could there be trash in the valve body,and it held long enough to back off the ramps,and worked a little while it was cold,but now nothen.thanks for all the help.
no reverse
thanks for the help,I will pull the valve body off first and look before I pull the trans and go in it again.
| Car Will Not Go Into Reverse?? | HotRodMan | Transmission - Rearend | 15 | 05-22-2007 02:33 PM |
| Making a reverse shape in sheet metal | John Kelly | Body - Exterior | 4 | 12-16-2005 08:24 PM |
| th350 reverse double apply??? | eskoskimo | Transmission - Rearend | 1 | 10-11-2004 05:07 AM |
| ford aod reverse shift | snoman | Transmission - Rearend | 2 | 02-17-2004 06:38 PM |
| 350tranny. no reverse. | Sonkey | Transmission - Rearend | 3 | 02-11-2004 11:31 PM |
