No Reverse..ford truck 5 speed transmition - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2007, 02:57 PM
MAYNARDTRUCKIN's Avatar
Last journal entry: new pic
I have a ford truck 5 speed transmition that i can not get in to reverse. it hits all 5 gears and drags in nuetral i think that one of the main berrings in the main shaft is sticking. Is there any way that i can free it up with out pulling it a part, or might i be on the wrong track. i could use any help given.
Old 07-17-2007, 08:17 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
if a bearing was sticking there should be a noise coming from the box, and the only fix would be replacing it, but I think the problem should be in other place maybe frozen sinchronizer rings or a worn/bent reverse shift fork.
take an oil sample and look for metal flakes
Augusto.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
new world truck speed record hoodoo Hotrodders' Lounge 4 01-10-2007 01:43 AM
ideas for reverse lights - '65 chevy truck Woogeroo Electrical 2 12-08-2005 06:48 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 04:19 PM
