no room for oil sending unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 10:35 AM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
I'm replacing the 79 sbc oem idiot light sending unit with a bigger one for a VDO gauge. Using the original location behind the intake under the hei distributor. The gauge sending unit is quite a bit bigger and the body hits the back of the intake so it won't fit into the hole. If I use adapters to raise it it looks like it will be too high and will hit the distributor. What are my options? Can I use and elbow? Is there a better location to mount it?
murray
Old 01-28-2007, 10:49 AM
MI2600's Avatar
Member# 3287
You can use an elbow. A lot of times an HEI will be a problem. I used a plumber's nightmare back there so I could have the light and a mechanical unit.
Another solution is to tap off the plug down by the oil filter.
Old 01-28-2007, 11:40 AM
murrsue's Avatar
thanks MI2600, I'm off to the hardware store. Why does this stuff happen on Sunday when most places are closed?
Hey I've often thought there's an advantage to having both the idiot light and a gauge. The light will catch your attention right away when you might not be watching the gauge.
murray
Old 01-28-2007, 11:59 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You remember the Dodge Omni/Ply. Horizons? They had oil pressure lights and gauges.
Visit Radio Shack and for about $4 you can buy a 90 db. piezio pulsating buzzer (about 1 1/2 inch diameterx 1/2 thick) and just wire it in parallel with your light, stash it under your dash.
Saved me one engine when my son was driving. Heard the buzzer, saw the light, etc.
You could also get a "Vega" oil pressure switch that cuts off the ignition when the oil pressure drops to 6 or 15, they make them both.
After 1,000,000 miles of driving, I prefer a light and a buzzer. Got em on my hot rods.
Old 01-28-2007, 12:06 PM
poncho62's Avatar
Wiki Edits: 5
I have used a 45 degree elbow, with success in that situation.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Fuel sending unit help. lt1bbody Electrical 1 11-04-2005 04:18 PM
aod speedo sending unit ? 56f100 Transmission - Rearend 2 09-30-2005 06:23 AM
tbi 350 oil pressure sending unit problem HELP orangebaja Engine 3 11-07-2003 07:23 PM
Where can I install my water temp sending unit? CHEV66JB Engine 1 05-11-2003 06:15 PM
