Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no shift indicator
Old 11-13-2013, 10:06 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by knight hawk View Post
OK, I see the pieces, but can't open a PDF, for the instructions... how does the plastic needle connect to the column ?
It sounds like the pointer attaches to the shift cone with 2-sided tape. The PRNDL indicator is screwed to the stationary housing at the very top of the column (turn-signal switch) housing.
Make sure that you have a current version of Adobe Reader installed on your PC, and then go directly to IDIDIT's website to download / view that PDF file.
You'll find it on the Resouces tab, under the Guides & Tips heading. Scroll down the page, almost to the bottom, to find: Column Add-Ons Instructions
Now pick the Shift Indicator with Housing Installation Instructions link to download the PDF instructions.
