-   -   no shift indicator (http://www.hotrodders.com/forum/no-shift-indicator-254914.html)
knight hawk 11-13-2013 07:00 PM
no shift indicator
this is on a "Hot rod" ( 42 Ford ), the steering column is a chrome, smooth column, no name or numbers, AND it has NO place for the shift indicators !! Would an aftermarket column have no shift indictor ??? thanks
Mitchman 11-13-2013 07:09 PM
You didn't say the shift lever is on the column... It would be on the floor shifter if so equipt. You can get a sender and indicator for the dash. I wouldn't build a car without one, and some states may require one. My wife.... valet parking.... tire store grunt... no bumpers. Yea, they are a good idea.
knight hawk 11-13-2013 07:35 PM
SHIFT LEVER IS ON THE COLUMN. ONLY OPENINGS IN THE TUBE ARE FOR THE WIRING HARNESS. tHE PERSON THAT BUILT THIS 'CAR' DID many THINGS WRONG AND UNSAFE. I AM SUPPOSED TO CORRECT IT !
66GMC 11-13-2013 07:50 PM
IDIDIT Shift Indicators
Instructions
knight hawk 11-13-2013 07:57 PM
OK, I see the pieces, but can't open a PDF, for the instructions... how does the plastic needle connect to the column ?
66GMC 11-13-2013 09:06 PM
It sounds like the pointer attaches to the shift cone with 2-sided tape. The PRNDL indicator is screwed to the stationary housing at the very top of the column (turn-signal switch) housing.
Make sure that you have a current version of Adobe Reader installed on your PC, and then go directly to IDIDIT's website to download / view that PDF file.
You'll find it on the Resouces tab, under the Guides & Tips heading. Scroll down the page, almost to the bottom, to find: Column Add-Ons Instructions
Now pick the Shift Indicator with Housing Installation Instructions link to download the PDF instructions.
33Willys77 11-14-2013 07:06 AM
Dakota Digital also has digital indicators you can put on.
Mitchman 11-14-2013 07:42 AM
There are also electric ones that attach to the trans with lights on the dash.
The one from Ididit is dirt simple to install. A few screws hold the 'needle' and the housing in place on the outside of the column.
Welcome to hot rodding. 50% inspiration, 70% problem solving, 20% drilling holes.
