no shift indicator - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2013, 08:00 PM
no shift indicator
this is on a "Hot rod" ( 42 Ford ), the steering column is a chrome, smooth column, no name or numbers, AND it has NO place for the shift indicators !! Would an aftermarket column have no shift indictor ??? thanks
Old 11-13-2013, 08:09 PM
Mitchman's Avatar
Grand Master of the Universe
You didn't say the shift lever is on the column... It would be on the floor shifter if so equipt. You can get a sender and indicator for the dash. I wouldn't build a car without one, and some states may require one. My wife.... valet parking.... tire store grunt... no bumpers. Yea, they are a good idea.
Old 11-13-2013, 08:35 PM
SHIFT LEVER IS ON THE COLUMN. ONLY OPENINGS IN THE TUBE ARE FOR THE WIRING HARNESS. tHE PERSON THAT BUILT THIS 'CAR' DID many THINGS WRONG AND UNSAFE. I AM SUPPOSED TO CORRECT IT !
Old 11-13-2013, 08:50 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
IDIDIT Shift Indicators
Instructions
Old 11-13-2013, 08:57 PM
OK, I see the pieces, but can't open a PDF, for the instructions... how does the plastic needle connect to the column ?
Old 11-13-2013, 10:06 PM
66GMC's Avatar
It sounds like the pointer attaches to the shift cone with 2-sided tape. The PRNDL indicator is screwed to the stationary housing at the very top of the column (turn-signal switch) housing.
Make sure that you have a current version of Adobe Reader installed on your PC, and then go directly to IDIDIT's website to download / view that PDF file.
You'll find it on the Resouces tab, under the Guides & Tips heading. Scroll down the page, almost to the bottom, to find: Column Add-Ons Instructions
Now pick the Shift Indicator with Housing Installation Instructions link to download the PDF instructions.
Old 11-14-2013, 08:06 AM
33Willys77's Avatar
Dakota Digital also has digital indicators you can put on.
Old 11-14-2013, 08:42 AM
Mitchman's Avatar
There are also electric ones that attach to the trans with lights on the dash.
The one from Ididit is dirt simple to install. A few screws hold the 'needle' and the housing in place on the outside of the column.
Welcome to hot rodding. 50% inspiration, 70% problem solving, 20% drilling holes.
tilt column shift indicator 49 chevy Hotrodding Basics 0 12-29-2011 06:35 PM
Dial indicator tommy evans General Rodding Tech 7 06-16-2009 04:56 PM
Does anyone have a lokar dash mounted shift indicator powerrodsmike General Rodding Tech 2 12-31-2007 11:43 PM
Gear Shift Indicator ARPEE General Rodding Tech 2 09-13-2006 08:36 AM
Pic indicator hot_rod_kid Hotrodders Site Suggestions and Help 1 12-18-2002 05:03 PM
