Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No shifts from 1991 700r4
Old 02-18-2011, 06:21 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
If the fail safe check ball is in place.. the minimum setting on the cable is important. If the minimum setting is not set correctly the check ball will seat and the trans shifts late like WOT
Have you checked the governor plastic gear to see if the gear is broken or worn out? Governor not turning, the trans thinks it is not moving = no shifts
