No shifts from 1991 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 10:14 PM
Hey all, i know this is a problem that has been discussed over and over however i have alittle more info to ad.
I have a freshly rebuilt 1991 700r4, it will not shift out of first!
Fluid level is perfect.
I have removed the governer and the piston moves freely and the teeth are brand new.
I removed the pan and checked the tv rod. It goes in and out just fine nice and smooth, i can push it in all the way and it snaps right back... I am using a lokar cable. And its adjusted right. I have tryed adjusting it loose and stiffer, no change.
As i drive, i have tried driving slow and also rapping on the throttle, one thing i have noticed is that if i alow it to pick up speed and increase rpms, as soon as i let off and then give a bit more throttle it feels as the trans is slipping. Once again the fluid level is correct acording to my tci dip stick.
I have tried to shift it manually, however no luck! I am stumped!
Any help would be great!
Erik
Old 02-17-2011, 10:51 PM
Update
When i shift manully out of N to D it will go into gear but never shift out of 1 gear however when i am just coasting and i shift all the way down to 1 it feels as it down shifts, so i am assuming that when i shift out of N to D its really going into 2nd?
Old 02-17-2011, 11:18 PM
dsgb610's Avatar
I be Strokin!!!
Throttle Valve cable?? I had similar is issues with my transmission.
Old 02-18-2011, 01:24 PM
Anyone have an idea
Old 02-18-2011, 01:32 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
If your transmission doesn’t shift out of first gear or shifts hard at too high a R.P.M. this doesn’t always mean you have a problem. This could be a stuck throttle valve caused by a small piece of trash. This sometimes happens after a rebuild. Sometimes the throttle valve can be unstuck without removing the valve body. Get up to about 20 to 30 M.P.H. and hit the gas pedal on and off hard with your foot. This might do the job. If that doesn’t work remove the throttle valve cable end from the throttle, with the motor at idle in park, pull the cable in and out very fast, this might work, if not the valve body must be removed by a transmission shop to be unstuck. This could cost $50.00 to $100.00.
http://www.transmissioncenter.net/700r4.htm
Old 02-18-2011, 05:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the fail safe check ball is in place.. the minimum setting on the cable is important. If the minimum setting is not set correctly the check ball will seat and the trans shifts late like WOT
Have you checked the governor plastic gear to see if the gear is broken or worn out? Governor not turning, the trans thinks it is not moving = no shifts
Old 02-25-2011, 06:54 PM
what kind of grease did you use to hold the checkballs in place during assembly? i rebuilt one recently and the grease didnt wash off very fast and caused the same thing you have. I drove it down the road and let it get speed down a hill and put the petal to the floor a few times and that let the balls wash off and started working right.
700R4 Shifts Too Soon 10mikeymike Transmission - Rearend 5 11-19-2009 07:20 AM
700r4 delay between shifts 79280ZX355 Transmission - Rearend 4 06-16-2009 09:39 PM
700R4, only shifts @ WOT Hotwire Transmission - Rearend 13 09-05-2008 08:14 PM
700r4 shifts pink63impala Transmission - Rearend 7 03-16-2005 04:57 PM
700R4 Shifts Keppie Transmission - Rearend 6 07-16-2002 11:48 PM
