no spark?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 05:32 PM
brianlarkin1993's Avatar
no spark??
got a 94 sunbird and it is not getting any spark at the plug.. any suggestions??
Old 05-24-2008, 07:25 PM
bad battery conections, bad wires , coil pac, starter wire might have broken
Old 05-24-2008, 07:28 PM
poncho62's Avatar
Wiki Edits: 5
Crank sensor, ECU etc etc.....could be many things......You need to give us more info.
Old 05-24-2008, 07:37 PM
no spark
If the car is equipped with it you most likely have a bad crank sensor easy way of finding out is looking for coil packs. If i remember correctly crank sensor controls spark and cam sensor controls injector pulse or vise versa. good luck
Old 06-16-2008, 03:28 PM
i bought a coil pack, and it did not fix the problem.. is the crank sensor located behind the timing belt cover??
Old 06-17-2008, 10:33 AM
bump..
Old 06-17-2008, 12:54 PM
sbchevfreak's Avatar
Licenced Automotive Technician
What engine???
Old 06-17-2008, 03:37 PM
2.0, but i found it.. crank sensor wire was pinched, causing it to ground out on the block..
thanks for all the help guys..
350 TBI spark problem driving med crazy!! Erst Engine 13 09-27-2016 04:39 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
No spark, please help Bill-E-BoB Engine 10 09-09-2007 06:36 PM
try again slow spark jackfrost51 Electrical 2 09-08-2005 07:01 PM
Can't restart engine Weak spark? Ratchet Engine 4 06-19-2005 06:00 PM
