-   -   no spark 1996 plymouth voyager 3.0 motor (http://www.hotrodders.com/forum/no-spark-1996-plymouth-voyager-3-0-motor-214471.html)
johnmelia 02-11-2012 03:47 PM
I checked the coil i turned the key checked for volts OK one wire going to coil. Inspected wires ohm to cap ok no spark??
EOD Guy 02-12-2012 05:10 AM
Seriously...... you need to provide more info.....Type/year of the motor,, Points or HEI, how did you check the coil? by turning on the key?
vicrod 02-12-2012 02:22 PM
Autozone offers wiring diagrams, testing and repair procedures for many production vehicles.
Go to www.autozone.com
You will need to register and create a password.
From the dropdown select the vehicle (new).
Select the category. Vehicle repair guides.
Next you will find listings of repair categories or chapters. Navigate to wiring diagrams, testing or repair procedures etc. Then select the desired item.
Check the cam and crank position sensors. They are often the problem.
vicrod
